Originally Posted by luvsrc
so you guys mean to say that i can use to charge my (2) 3s maxamps 5000mah lipos "just wire them in series "using a series adaptor and i can use the 989 charger or whatever charger capable of 6s and 5000mah?thanks for all the replies
Like Jhautz said, "You can do that as long as the 2 3s packs are balanced to each other"
The MRC 989 will also allow you to use a parallel connection for those 2 - 3S Packs, then charge at 10 amps. Same charging time to full.
I usually charge at a rate somewhat less than 1C though. This is said to lengthen the cycle life of the packs, over charging at the maximum rate.
