04.30.2008, 01:14 AM
You will have to have a custom harness made to balance the packs in parallel with one balance. Check out briang's sig, he has some diagrams there that you can play with. Oh, forgot to say "BALLS"
04.30.2008, 02:19 AM
man, everyone's bustin my..... Ooooh! something shiny........
04.30.2008, 02:33 AM
so if I just hardwire the pack leads and balancer leads from each pack together in parallel they'll always be balanced to each other, just like a purchased 2p pack, correct?
04.30.2008, 02:35 AM
Yes, but I would make harnesses. Mainly cause I like to. Will you stack the packs and tape/shrink them together?
04.30.2008, 02:45 AM
nope, riding on either side of the center diff on my e-maxx, motor mounted above diff for perfect balance, due to the placement harnesses would work better and look cleaner while the batteries are on the truck, I haven't done any wiring in some time, good excuse to buy a stripper. Oh, something to take the insulation off the wire might be a good purchase too..............
04.30.2008, 02:47 AM
nope, riding on either side of the center diff on my e-maxx, motor mounted above diff for perfect balance, due to the placement harnesses would work better and look cleaner while the batteries are on the truck, I haven't done any wiring in some time, good excuse to buy a stripper. Oh, a wire stripper might be a good purchase too..............
Hmm, I just pay the stripper per dance...
Wire strippers are great, I have dozens. I like to buy stuff...
04.30.2008, 02:52 AM
you're right, renting sounds like a much better option, then I don't have to feed it.
