As noted, you HAVE to lock the first diff, or else it will just unload on the side that has nothing connected to it. At that point, you may as well be using a spur gear there. There is absolutely no benefit to the added rotational mass of a diff if you have to lock it anyway. You can argue all you want, but there is absolutely no reason to have a diff in that location.
