1512 1d on 4s 2170 mah? I think you seriously need to reconsider you setup or else something may blow up. The motor is really a 3s motor since its not a good idea to run it past its rpm limit, and there is no way the 2000 mah batteries will support the required current unless they are rated for 60c continuous.
