Sammus
Sammus's Avatar
05.02.2008, 12:08 AM
Originally Posted by DrKnow65 View Post
well, you gave up like 230kv, go up to 6S or try some much taller gears. If you are experiencing no heat, you have PLENTY of head room for taller gears.
I wouldn't recommend this at all. Most Mamba Max's can't even handle 5s let alone 6s. Gear up instead.
In answer to your question, everything else equal, changing the ESC shouldnt really affect the top speed. For that you either need higher voltage or high gearing. If you got the Monster, then you could run 6s which would give your more speed.
