Batfish
Batfish's Avatar
09.18.2005, 02:54 PM
Originally posted by MetalMan
I have read that Deans are rated at 60amps cont. and much higher in bursts. Powerpoles are good connectors, but they are rather bulky, and crimping the wires on will create higher resistance than soldering.
Not to be argumentative, but a crimped connection has less resistance than a soldered connection, all other things being equal. This is the best way i can describe it:
With a crimped connection, all of the strands of wire either touch each other or touch the connector directly, offering a direct path for the current to travel through.
With a soldered connection, the solder gets between the strands and connector as well as between the strands themselves. This puts a higher resistance substance (solder) between the current and it's destination.
If soldered wire was better, we'd put solder inside short lengths of wire to increase their capacity. Strand-to-strand is a better conductor and, generally speaking, the more strands the better. A soldered wire essentially turns all of the strands into 1 at the connection point.
However, you are correct in that the PowerPoles are larger connectors.
Yes, I have also read that the Deans are rated at 60 Amps. It's just impossible to get information from WS Deans themselves. Their website hasn't been updated in years and none of their products come with spec sheets, so all we have to go on is what other sources say.
As far as PowerPoles, since they aren't specifically designed for R/C use there are many, many people using them for a large amount of different applications. This makes quite a bit of data available about them. Here's a quote from the article I linked earlier: The actual rating for a 30-amp Powerpole is for a 30° Celsius (54° Fahrenheit) temperature rise at 30 amps (and 110 volts) using 12-gauge wire. This temperature rise spec is published in the National Electrical Code for building wiring and is more of a wire gauge rating than it is a connector rating. The power level noted in that standard is 3,300 watts.
I think the 30A rating on the PowerPoles themselves generally makes people think they are weaker connectors than Deans.
Joe
