david lamontagn
05.07.2008, 10:43 AM
Originally Posted by austinmaxx View Post
its crazy they should have changed the lvc to have it where it has to hang at the low voltage for bit before it trips the lvc switch vs the dipping voltage for split second and it trips...i have two MMM's on order ....mgm is going to lose alot of customers here real soon...
You're right, but mine on reduce rpm still work fine. But as i said, i'll run it on Race Mode, and i just race with my buggy, so i did a 5 minutes race and after that i'll re-peak my pack, so i don't worry about the li-po low voltage
