Five-oh-joe
05.05.2008, 01:14 PM
Works for me. That's a beastly truck buzz.
I just came back inside from an approximate 10-12 minute run with the Rustler (I'm trying to limit runtime to about 10-15 minutes so I don't kill my lipos). Everything is the same as previous tests, except this time I loosened the slipper by about 1/6 of a turn, and geared up to a 27 tooth pinion (27/87 so about an 8.764 FDR) .
Conditions:
-Night
-about 84F out with a very warm breeze
-muggy/humid Florida summer night
Temperatures:
Motor- 115F
ESC- 110F
Battery- ~110F with case on, 135F without case on bare cells
So far the Medusa+Mamba setup is great! I wish I could have tested it today when my 1:1 truck's temperature display said 92F though... Took forever to balance charge this pack (I balance charge the pack at .75 amps now since I've been pushing it super hard).
Comments:
I tried everything I could think of to get the motor to heat up. Tons of wheelies, tons of WOT passes and 180 degree turns where I'd brake to spin and then jam the throttle down to get as much current drawing as possible. Motor seems to be quite "happy" at this gearing. The real test will come maybe tomorrow or Wednesday; my vista gadget says it'll be about 87F tomorrow for my area (probably hotter in the middle of the day I'm thinking).
glassdoctor
TEAM FUSION
glassdoctor's Avatar
05.05.2008, 10:16 PM
Originally Posted by Buzzsaw46 View Post
Not sure why there was no sound, it works for me. Anyone get no sound from it
It's just me... my computer has an "issue" at the moment... sound cards no workie and I've tried a couple different ones. I need to try new drivers and see if I can get her going.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
highflier
Emaxx- FLM wannabe
05.05.2008, 10:22 PM
Maybe it is your speakers......
The power supply or the volume is turned down. Some of em have on off for th amp.
Highflier
glassdoctor
TEAM FUSION
05.05.2008, 11:45 PM
Nope... speakers are ok... checked that out. I might have a bad MB... but there is a driver conflict now in the hardware config settings. I just checked it again... had not messed with it for a while.
Before it would say "this device is working properly", etc like there was no problem. At least now I have some hope that I can get ti fixed with drivers or reinstall or something.
I've been too busy to mess with it... maybe I should get off the internet huh? LOL
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
killermmn
killermmn's Avatar
05.06.2008, 02:30 AM
can someone whit this motor post a video if possible??
SypderFungus
05.06.2008, 02:43 AM
I have this motor. What kinda video do you want? Bambi? Toy Story?
killermmn
killermmn's Avatar
05.06.2008, 02:46 AM
speed run or bashing run
bruce750i
bruce750i's Avatar
05.06.2008, 12:09 PM
LOL, One vote 4 Bambi.
fastbaja5b
fastbaja5b's Avatar
05.06.2008, 08:43 PM
Does anyone have any gearing ideas for a 36-50-3300V2 in an E-Savage on 12 Nimh cells (switching to 2* 2s2P A123 cells) I have an 18t on there right now and it doesn't feel any faster than the Ammo 2600. I have the timing set at 10 degrees at the moment.
Motor comes off at 110 degrees without a fan, standard heatsink as the Medusa one doesn't fit the E-Savage transmission to well, ESC has a fan and comes off at 90 degrees. Batteries (Nimh) come off at 100-120 degrees.
jfruge
05.07.2008, 05:06 AM
Well I just ordered a Medusa
36x50mm 2200Kv V2 Afterburner Brushless Motor, w/Bonded Finned Heatsink.
5mm Shaft
I plan to use it on my sons 8ight buggy on 4s 5000
Fun Fun
John Fruge
Madera, CA
8ight pro buggy, RCPD Ultimate, 4s TP 5000, MM ESC , NEU 1512/3d, JR Z8800T
8ight pro buggy, RCPD Ultimate, 4s TP 5000, MM ESC , Medusa V2 36x50mm, JR Z8800T
jfruge
05.07.2008, 10:44 AM
5mm Shaft
Fun Fun
Anyone have any thoughts on a good safe pinion size for this setup? I have the 46T plastic spur, 4S 5000 lipo on a 8ight buggy. I am looking for a good driving setup and not all out top end speed. I think my local track is mid size and med. bite. In the Novice class were only running 10 minutes mains as well.
Thanks,
John Fruge
Madera, CA
Buzzsaw46
05.07.2008, 11:18 AM
I would say a 12-14t John. That sould give you a good range of speeds through the mid to upper 30's possibly into the low 40's
jfruge
05.07.2008, 01:09 PM
Thanks for the info. I should have these conversions going before too long. I just got a PM that the RCPD EL8 conversion kits I had on order shipped yesterday.
Fun Fun,
John Fruge
Madera, CA
Motor
xcellr8n
Motor - 05.08.2008, 10:59 PM
I just installed a medusa 36-60-1600 in my losi 8t about a week ago. I am running it on 4s 6000 pack. I do not have alot of experience with different motors but I was running a nemisis xlt motor before this. This motor has plenty of power and seems to have just as much torqe and speed if not more then the nemisis. Raced a 20 min main this past weekend and temps came in at 135/motor-114/esc-95/battery. I am liking this motor so far.
Tim
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.08.2008, 11:06 PM
Any idea the weight on your 8T? Thanks for the review by the way.
www.cubicle101.com
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
