New Firmware for MMM -
05.08.2008, 10:15 PM
05.08.2008, 10:21 PM
Stay Clear!
Yip Yip Yip...
05.08.2008, 10:43 PM
Were there any changes in that though for the MMM?
Yip Yip Yip...
05.08.2008, 10:45 PM
Installs fine for me too. Maybe try deleting cache and download again.
I don't understand, but I don't think I like it.
05.08.2008, 11:20 PM
I had the same problem a week or so ago. I just ended up uninstalling THE Castle Link software and reinstalling the previous version (V3.04).
05.08.2008, 11:31 PM
Ouch. Is that installing it by doing "run as administrator" too?
Yip Yip Yip...
05.08.2008, 11:37 PM
Must be a vista security issue. Works fine on XP.
05.08.2008, 11:45 PM
I had this problem when I had the Mamba Max ( 1 1/2 years ago) Ill try and find out what I did to correct it
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
05.08.2008, 11:46 PM
I'm running XP SP2.
05.08.2008, 11:47 PM
Mine installed and works great on XP sp2. Download a fresh copy.
05.08.2008, 11:51 PM
the SW upgrade was for helicoptor /airplane use...maybe this is the problem
05.08.2008, 11:55 PM
I did re-download it and try installing it again with the same outcome.
Yip Yip Yip...
05.09.2008, 12:10 AM
Did you clear your cache before downloading again?
05.09.2008, 12:35 AM
Also, are you using a download manager? Some sites don't like that...
05.09.2008, 03:27 AM
Yes. It corrects an issue with the MMM not running when a cutom cutoff voltage was selected. I worked perfectly on AutoLipo setting, but with any custom settings it would not run. This update fixed the problem I downloaded it and updated tonight and it works perfectly on custom cutoff now.
to make it...
or break it...
Silent...But Deadly
