How did the trip to China go?
How did the trip to China go? - 05.08.2008, 05:15 PM
PdC any update on the motors - winds, specs, thoughts on factory or local food?
**gger - BrianG can you correct my typing of China!&*!%^*!
Last edited by MetalMan; 05.09.2008 at 04:48 PM. Reason: Fixed spelling of China :)
Pdelcast
Pdelcast's Avatar
05.08.2008, 05:34 PM
China summary -
Factory adding capacity every day. By end of June factory should be at double April capacity.
Worked through several issues with 1515 rotor assembly and balancing. 1515 nearing production, but still some issues to work out with getting consistent quality on magnets.
1515 motors dyno'd very well, Kv at 2150 RPM / V. Ran several batteries on Emaxx with 1515/1Y (6S setup.) Found motor requires cool down between each run, maximum motor temp was around 85 degrees centigrade (29 degrees ambient) This was a VERY heavy setup with 10AH 6S battery.
Local food -- really good fish called "skinless cow fish" (direct translation) Anybody know the English translation? Ate way too much Dim Sum...
Patrick
skellyo
skellyo's Avatar
05.08.2008, 05:39 PM
A cool down between runs isn't bad considering you were running 6S on it. I couldn't imagine being able to keep a vehicle in one piece running 6S on a 1515/1Yish for an entire battery pack, let alone multiple packs.
05.08.2008, 05:41 PM
Oops - Cowfish seem to be an endangered animal!
http://www1.china.org.cn/english/environment/34742.htm
http://www.hbj.hunan.gov.cn/dongT1/w...ay.aspx?id=133
http://en.wikipedia.org/wiki/Finless_Porpoise
Pdelcast
Pdelcast's Avatar
05.08.2008, 05:44 PM
Don't think it is the same fish -- what we ate was a saltwater fish, not a freshwater (river) fish...
05.08.2008, 05:47 PM
One of these!?!
http://animal-world.com/encyclo/mari...rs/cowfish.php
www.cowfishes.com
Pdelcast
Pdelcast's Avatar
05.08.2008, 05:49 PM
LOL, no not one of those! :)
I think we will need someone who is Cantonese to give us an idea of what kind of fish... it doesn't translate to English.
Patrick
Serum
Serum's Avatar
05.09.2008, 01:44 AM
So i am not good enough for you?
ogrfre01
05.09.2008, 02:25 AM
Patric: Are you only planning on producing 1515-size motors, not any 1512-size?
JeffEmbracedDC
JeffEmbracedDC's Avatar
05.09.2008, 02:41 AM
1515 motors are coming first with 1512 length coming afterwards.
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
ogrfre01
05.09.2008, 03:36 AM
Ok, so 1512-size is also planned, it is just comming later?
Pdelcast
Pdelcast's Avatar
05.09.2008, 03:39 AM
Yep! 1515/1Y will be the first, with Kv of about 2200
Second will be the 1512/1Y with a Kv of about 2650
(dang jet lag! Go to sleep at 11:00pm, wake up at 2:00am wide awake!)
Patrick del Castillo
President, Principle Engineer
China
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
China - 05.09.2008, 03:47 AM
Hey patric what part of China were you in? I got to visit Beijing two years ago and we did all of the touristy things, like the Square, the forbidden city, and the Great Wall. Great vacation and good food. The HardRock was a little disapointing though. Sounds like good news with the production of the motors, so when do you think they might be in stock for purchase? Summer is almost here.
ogrfre01
Yep! 1512/1Y will be the first, with Kv of about 1650
Ok, thanks for the reply, that is what i was hoping for..... i probably want a 1512-sized motor, however i would like for it to be around 2000 Kv as i am driving on 4 cells..... but i guess there will be a couple of Kv-choises later on. I commend you (CC) on your work!
Pdelcast
Pdelcast's Avatar
05.09.2008, 03:56 AM
Hi Jerry!
Was in the Zhongshan, in the Guandong region. Real near Hong Kong (about a 2 hour boat ride from HK.)
Food is always good... but it was HOT in China already!
Patrick
