crazyjr
crazyjr's Avatar
05.10.2008, 05:56 AM
I have to fourth the Mini Quake SE, I put mine through 7 levels of hades and it has survived well. I was running a 4700 golden horizions motor w/ a mamba 25 and 6 cells of NIMH (1400) and it would run and jump like a bigger truck. Our track at that time, had a dirt mound with a step type ramp to leap over it, distance to landing was about 15 feet and most buggies and truggies (1/8) would go 20+ feet. My MQ could come within a few feet and land, as though it were a bigger truck. The tumbles it took while trying to land that and many backflips (From 8+feet in the air) Gave it the name of the scud, As in the Iraqi missle that almost never landed where it should, it never broke in nearly a year of punishment. I do recomend that you tighten the diffs, they will loosen from time to time. I currently have a Neu 1107/2Y (3400kv) on a Mamba 25 esc W/1800 3s lipo, That setup is like a 2250 in a Emaxx on 6s Lipo, Just too much, The diffs are slipping but the Drivetrain is holding other wise
