Most likely your monitor has 1 DVI and 1 VGA port. These are both inputs, so that you can connect your PC to one or the other depending upon the type of video port your card has. The VGA port is not an output, so it will not send signal to your tv.
Once you get it hooked up to the PC you should be fine.
