I have a spare motor and a spare speed controller. The only problem is that the motor is a 18th scale Dynomite C4 9200kv and the controller is a BK 9920.
Over kill on the contoller I know but would it work?
Yeah that's it. I was gonna say you need to keep the voltage under like 5 volts or it will over-rev the 9920. I believe the limit is 42k. That's a 1S motor!
Well I just tried it on a 1s that I had. Same pulsation. I will try to reprogram it and see if that does anything.
