Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
05.19.2008, 04:24 PM
Anyone who has issues with a MMM...send it in with a copy of the service request form. We are making these top priority right now. We'll give you the fastest service possible as this is a new product, and you've all waited long enough to have fun.
http://www.castlecreations.com/suppo...quest_Form.pdf
Joe Ford
Product Specialist
Sower
Sower's Avatar
05.19.2008, 04:33 PM
Dang, I already sent mine back w/o any form. Just a note to you or Patrick. I did send him a PM though - does that count for anything?
MBX6T Tekin RX8 5s Neuenergy
www.robsower.com
finfin
05.21.2008, 12:18 AM
hi joe
in my country, thailand, there are 3 MMMs. All 3 owners are my friends. I would like to know,.can we send all 3 failure MMMs in one mail box to CC if all 3 are fail?
Joe Ford
Joe Ford's Avatar
05.21.2008, 05:02 PM
Originally Posted by finfin View Post
hi joe
You can send them all in one package. We will ship back to whoever sends the package in.
Joe Ford
Product Specialist
phatmonk
RC carbon junkie
phatmonk's Avatar
05.21.2008, 06:19 PM
Darn my second MMM died.I switched my 1515/1.5 4s for my 1515/1d on 3s 6000.It just stopped like the first one.The 1515/1D max amps is 200A.The system wasnt even warm.It ran flawless yesterday with the Tekno Neu 1515/1.5d.I should not have swapped the motors
Losi 8T MMM? Tekno Neu 1515/1.5/f 4s 6000/Neu 1515/1d/s 3s 6000
Crt.5 Quark 80B Neu 1512/1d/s 3S 6000
xtremelimits285
E8ight T
xtremelimits285's Avatar
05.21.2008, 06:29 PM
Probley was going to die soon anyway, by swaping motor/batteries, just showed the esc was a bad one..
that does suck though
Gary Antonietti #9
Losi 8ight T - Monster Mamba - Neu 1515 1y - MaxxAmps 3s/4s/5s 8000mah - Futaba 2.4GHz Tx/Rx 6EX - Futaba S9351 servo - 15/46t gearing
FTT3 -Mamba Max - 2s 8000mah
  Send a message via MSN to xtremelimits285
Joe Ford
Joe Ford's Avatar
05.19.2008, 04:36 PM
Doesn't matter if you sent the form or not. We'll still get you fixed up asap. As long as you put your return addy in there we're good to go.
Joe Ford
Product Specialist
Sower
Sower's Avatar
05.19.2008, 04:38 PM
I figured as much!
www.robsower.com
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
05.19.2008, 06:16 PM
I sent it with the form. Make sure you repair mine before sower's since he forgot the form .
Sower
Sower's Avatar
05.20.2008, 11:14 AM
Nice - that's hilarious
It will be interesting to see what the cause of the failures has been. After opening mine up and seeing how the wire separated I think that might be a main cause. Like I really know
www.robsower.com
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
05.19.2008, 06:51 PM
I'd just like to say that you Castle guys are doing an awesome job in dealing with these issues. I know it must be a bit of a nightmare, having spent all this time developing a great controller and being let down by defective components! You're being extremely involved (especially being active on the RCM forums) with this situation, and doing your best to rectify it with minimum hassle, so I take my hat off (if I had one on lol) to Pat and Joe. That's what customer service is all about.
I've still got my MMM waiting for a vehicle to go in, so I hope it's a good 'un, but if it isn't then I know I'll get taken care of. LOL that sounded cheesy, but it's true! Nice one guys. :)
RBMike
RBMike's Avatar
05.19.2008, 08:10 PM
For sure +1. Even though mine died, I'm not the least bit upset about it because I'm sure they will take care of it. Just will miss getting to run it that's all. It's too fun this brushless buggy thing.
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.20.2008, 11:21 AM
Well, fedex says mine just arrived at CC so whatever happens they better kick both of yours out of the way to fix mine!
Just kidding, as long as I get it back early next week I will be happy. I want to try the new Medusa out and it looks all lonely just sitting on the floor waiting for a home.
www.cubicle101.com
Sower
Sower's Avatar
05.20.2008, 12:12 PM
Well, I sent mine yesterday morning USPS Priority so I don't think it will get there until tomorrow. So I think you're safe.
www.robsower.com
05.20.2008, 04:59 PM
Not responding to anyone's post in particular, I was thinking about the seemingly continual controversy about the death of batteries using the MMM. These are the facts as I know them:
#1: Batteries that cannot sustain high currents without substantial voltage drop exhibit higher levels of current ripple. This can mean lesser-quality cells that are rated "optimistically" or cells that simply don't have the C and mAh rating combination. And before anyone chimes in, I'm not talking about MA cells in paticular, but any cell.
#2: The MMM (capable of 200A) probably has less total rdson value than the MM (capable of 100A). OK, this is not a fact, but an assumption.
#3: The MMM seems to be more sensitive to batteries than the MM for the same setup. Again, not a fact, but an observation.
#4: The issue with the UBEC dying is now attributed to a batch of less-than-stellar components. Ok, this isn't really related to the point, but I thought I'd throw that one in just to have a comprehensive list.
The only conclusion I can come up with for #3 is that the slightly higher rdson value in the MM setup helps to slightly reduce the battery's available current to the motor. Not much, but enough. The MMM is a "larger pipe", so the motor is free to pull as much current as it needs - at least slightly more so than the MM. This higher level of current causes more ripple current and is not good for batteries.
Does this sounds plausible? Does anyone have eagletree graphs of the same setup comparing the current levels using the MM and then the MMM? Would a few more caps to the battery input leads help protect cells like in #1?
