About time Kyosho bought out another Truck
Newly designed chassis boasts powerful performance from the center-shaft drive 4WD.
Fully assembled Readyset. Includes printed body complete with color scheme.
Features high-torque KS-302DS servo for steering and KS-3DS digital servos for other controls.
Equipped with newly developed strengthened New QRC transmission that shifts into reverse with the 3rd channel switch on the transmitter.
Almost symmetrically divided center shaft 4WD realizes control-friendly response.
Upper and lower sub-chassis structure incorporates the front and rear bulkheads for greater strength and rigidity.
New front and rear differential gear units feature additional support around the drive shaft bearings for increased durability. Includes two-bevel gears using tough machine cut helical gears.
Maintenance-friendly design enables easy removal and reassembly of radio box, transmission, engine and suspension shafts etc.
Equipped with dust proof radio box that not only protects the receiver and batteries etc. but also contributes to chassis rigidity.
In addition to the suspension arms, the knuckles, shock stays, gear boxes and shocks are interchangeable between front and rear for efficient maintenance and parts utilization.
New Touch Starter unit features safety circuit and delivers stable plug heating for easy engine starting.
Large capacity 103cc fuel tank supplies the 18-size engine to deliver run times of about 8 minutes.
Includes stylish chrome wheels as standard.
More Photos/Info
http://www.kyosho.com/eng/products/r...duct_id=103619
http://forums.radiocontrolzone.com/s...d.php?t=248381
