BOOGIE444
05.15.2008, 02:02 PM
Originally Posted by dpb318 View Post
would a 49 spur be a good start with a 20 tooth pinion, im going to be just bashing so less heat and lower top end is perfect for me (also would putting a fan on the motor heatsink help at all?)
just to clarify, a higher tooth pinion is less bottom end, more top end and a higher tooth spur is the opposite?
49T spur & 20T pinion would probably be alright to start out with, just watch your temps frequently when experimenting with new gearing.
Larger pinion means more top end, smaller spur also means more top end / higher gearing. Personally I wounldnt bother putting a fan on a motor.
