fromdaboz707
05.15.2008, 06:44 PM
You need a specific lipo charger - the hyperion ones are nice.
The MMM has a LVC (low voltage cutoff) that will protect the battery from going under 3v per cell i.e. 15v for your battery.
ok but do i heard that u are not suppose to let a lipo battery go all the way down is that true and i also heard that u are not suppose to charge it all the way is this true?
83gt
05.15.2008, 07:03 PM
Read Arct1k's post again. He answered you.
You use a charger that is specific to LiPo. Yes, you let the charge complete, and the packs should be balanced during or after each charge.
The ESC will automatically cut off at voltage for you, BEFORE you run them all the way flat. You can specify the voltage to use. Generally 3.0v is considered safe, but I think most of us stop around 3.2v to try and squeeze longer life from the pack.
J.
05.15.2008, 07:08 PM
Balance packs before or during the charge, never after. If you carge an unbalanced pack fully, one cell could go over 4.2v. I like the balancers (v balance, lba10) that you can charge thru. That way the balancer has control over the charge, and if a cell goes over 4.2v the balancer can interupt the charge. really safe that way. Plus you spend less time, as the balancing happens during the charge. Almost every time I charge the balancing is done before the pack is fully charged.
fromdaboz707
05.15.2008, 07:16 PM
ok what is a i was looking at the Hyperion EOS0606i is this a good one?
azjc
05.15.2008, 08:02 PM
if you can spend a few extra bucks get the 0610i it has a higher output, and can charge up to 10amps
fromdaboz707
05.15.2008, 09:30 PM
ok will that make a difference in how fast the battery will charge?
