05.16.2008, 04:06 PM
Thanks for the email addy lutach!
The c50 maxx uses a s can length rotor in a l length can. Basically gets higher rpm from using the smaller rotor. You could buy a l can rotor and put it in the hacker, which should give you around a 2000kv motor.
The windings appear to be a 13l, but the lighter, smaller rotor ups the kv rating.
Do you know what the l length rotors cost lutach?
lutach
lutach's Avatar
05.16.2008, 04:11 PM
I only asked for a price of the 5mm shafted rotor for the C50-maxx motor and that's what he gave. I did swap the rotor fro my 13L into the C50-maxx and they fit like a glove. So when you guys e-mail or call Kyle ask for the C50-L rotor and not the C50-maxx rotor.
05.16.2008, 04:17 PM
When you swaped the l length shaft/rotor in what kv did you end up with? Was it similar to the 13l, they output wires look to be the same diameter.
I have a 13l, 14l, and an 8l, and the 8l has much thicker wires coming out of it.
lutach
lutach's Avatar
05.16.2008, 04:25 PM
Didn't run it yet . I'm not sure if I will. I might just put the rotor back in the 13L and do some surgery on my Mr. C MBX5T kit to make it fit. I'm also undecided if I should go with the C50-13L or the ION-X that sems to be a C50-13XL, but gray instead of purple (Barney drives me crazy, I any Barney I see). I was thinking of removing the purple from all my motors .
