Traxxas vileon limits? -
05.17.2008, 05:34 PM
Hey guys, i just wanted to know if the Traxxas vileon ESC can handle 5s? i know my MM can and uses the same 25v components... i might be getting myself a vxl rustler here in a bit
05.17.2008, 05:41 PM
I wouldnt count on it....I hated the VXL ESC, I broke the connectors off of the ESC the first time I ran it, went to MM and never looked back
WARNING: May become violent.
05.17.2008, 05:57 PM
Has an overvoltage and wont let you use anything past 3s.
RIP- Tammy (9/14/08)
05.17.2008, 06:15 PM
ok, anyone know what the rpm limit of the MM esc is?
Team Thermal Racing
05.17.2008, 06:27 PM
Lots  Vassmar has a MM7700 on 5s in his TC4 which is well over 100k rpm.
My Rides:
Tamiya Dark Impact - Team Losi Micro B - Cen Mini Madness - Soon to be BL Xray XB8 TQ
05.17.2008, 06:49 PM
wow!! does anyone know if the VXL motor can handle 65k rpm?
05.17.2008, 06:57 PM
Maybe for a little while before it conks out, but that's definitely over its rated limit (if it's rated at the same RPM limit as most feigaos). It's got a larger diameter rotor than a CMS motor, so you'd definitely be pushing the envelope running that motor that fast. Current draw would be hell too at the voltage required to get the motor up to around 65k RPM.
05.17.2008, 07:00 PM
lol its only 5s :D
05.17.2008, 07:08 PM
That's "only" a possible exploded rotor...  Feigao rotors suck; I already had a 20x45mm feigao's rotor go boom on me running 3s in my Trinity NOW (stock setup from the factory at that too!).
Meh...
05.17.2008, 07:10 PM
I heard that the rotors in the Vxl are higher quality
05.17.2008, 07:18 PM
Physics doesn't care...  It's not a kevlar or carbon fiber wrapped rotor, so I still say it'll crap out.
It may not do it immediately, but the forces are that much greater when you spin it a little under twice what it normally spins in the VXL setup (35k RPM vs. 65k RPM).
It becomes a question of "how much sooner" as opposed to "if". You can take the chance if you want though. Gotta post pictures once it does go kablooey though....hehehe.
05.17.2008, 07:25 PM
hehe i know, i might get a Rustler vxl, probably gonna get a 3300mah zipy 3s pack for it
2 KiloWatt RACER
05.18.2008, 01:08 AM
I've seen a VXL rotor split allready. They are not high rpm motors. They are cheap for a reason.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
05.18.2008, 06:47 AM
hehe i gues its telling me to get a 1509
05.18.2008, 06:57 AM
Does anyone know how the Vxl esc will handle multipole motors?
