Us thicker center diff fluid if you notice the front tires spinning faster, and growing very big on hard acceleration. If you go too thick You may notice that the truck does not turn as tight as before. The thicker fluid helps the diff put the power to the rear wheels, but will also limit the difference in speed between the front and rear diff when turning.
