05.21.2008, 01:28 PM
It sounds like everything is working OK, and the setup sounds right. Other things to look at:
- Are your batteries up to the task? Weaker/tired cells won't be able to deliver the current required.
- Are the connectors (power and motor) dirty, loose, or soldered badly? Those won't pass the current effectively and will also cause voltage drops.
