View Poll Results: How's you Monster doing?
Failed on 4s lipo 5 8.93%
Failed on 5s lipo 7 12.50%
Failed on 6s lipo 6 10.71%
Working on 4s lipo 23 41.07%
Working on 5s lipo 3 5.36%
Working on 6s lipo 12 21.43%
Voters: 56. You may not vote on this poll
Edumakated
05.27.2008, 12:27 PM
I have two dead ones... running on 3s and 4s.
1) I believe this one has the faulty BEC. Running well for 3 weeks and just suddenly died. Broke the fan on this one. It disconnected from the board
2) This one smoked after one day of usage (4 packs through it). Basically stopped in the middle of driving up and down the street. I turned it off and then back on. Gave me a nice puff of smoke.
Both going back to Castle today in the mail.
rabosi
05.27.2008, 04:22 PM
I'm starting to think that eventually most of these first run controllers will fail.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.31.2008, 04:31 AM
Hope not.
Anyone found a fan that fits the mamba case yet?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
RBMike
RBMike's Avatar
05.27.2008, 08:05 PM
On the poll I checked 5S but mine really failed on 6SA123's (after about 90 minutes of runtime).
mkrusedc
NeuMaxx
mkrusedc's Avatar
05.31.2008, 03:57 PM
30 minutes today on 4s no problems yet. I'll buy some 6s today........
cemetery gates
05.31.2008, 11:55 PM
Today was the first run for my CRT with the mamba monster. I ran 3 4s 8Ah packs through it with out the bec going or ruining the fan. So far, so good! Mine is from the first batch too...
Temps were as follows:
Motor(1515 1y) 140*F
ESC(MMM) 101*F
Lipo(TrueRc 4s 8k) 120*F
This was in really muggy 85*F at the track under racing conditions.
Bye
killjoyken
RC-Monkey Poo Flinger
killjoyken's Avatar
06.01.2008, 01:43 AM
Ok, so we've completely ruled out voltage as a factor and by the looks of it, it seems that it's only a relatively small percentage that has the faulty BEC components. As for the fan, well....
My fan actually stopped working yesterday, but I found a blade of grass blocking it. Removed the grass and that wonderful turbine noise returned. Too bad the Muchmore fans I've been using on my MMs with zero failures are too tall to fit in the case. I may end up mounting them to the top of the case if the stock one fails.
My Monster has gone through about 5 full 4900mah 4s packs and is still running, so I'm pretty sure I got a good one. I'll be wiring up my second Monster (also from the first batch) tomorrow and trying it out so I'll be keeping my fingers crossed.
RBMike
RBMike's Avatar
06.02.2008, 10:15 AM
I got some time to run my repaired MMM this weekend. I put about 45 minutes total on it and it seems to be working fine. I am missing 1 blade on the fan (not sure where it went). I did however have a receiver problem. In the middle of one run the car stoped. I found thet the receiver had lost it's "bind" (Spectrum SR3100). I re-binded the radio and all was well for about 15 more minutes. Then the car stopped again. This time the receiver had lost bind again and would not bind. I put in another receiver when I got home and it seems to be fine again. Not sure if this is a random RX failure or MMM related.
nolatron
E-Revo Basher
nolatron's Avatar
06.02.2008, 10:21 AM
about 5 runs so far on 6S A123 with no problems yet.
bl-is-future
bl-is-future's Avatar
06.03.2008, 08:10 AM
I was with in the first batch of towerhobbies and mine is still running great. Have about 3 runs with 4s 5000mah maxamps with an 8xl and about 5 runs with 5s 5000mah flight power with a Neu 1515 1y. No fan failure nor bec failure. I am running it with the MMM bec that is built in too. This is all in a BL FLM Savage 16/47 locked in 2nd from a 3 speed.
finfin
06.28.2008, 10:44 AM
:UPDATE:
4s for over 3 hours 8XL, 7XL, ext. BEC, AND 4000 MAH LIPO
and 6s for 1 hour and a half with 9XL feigao, 65t spur , 18t pinion, ext. BEC, AND 4000 MAH LIPO
ps. not sure how long it will alive
DRIFT_BUGGY
06.28.2008, 05:50 PM
Still working on 5S for around 3 hours with Ext. BEC, standard fan, NEU 1512 2.5D
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
George16
Supermaxx
George16's Avatar
06.28.2008, 07:04 PM
Mine still works. All stock running with 6S Neuenergy 5000mah, Tekno RC neu 1515 1Y.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
e-mike
e-mike's Avatar
06.28.2008, 07:48 PM
ive got about 6 hour on first mine using the esc bec i try a 7xl.6xl.9l.and now i run a 1515 1y no issue at all... my other mmm run good whit a external bec....on 3 cell with a 9l(feigao) this week im gonna try without the ubec im scared
VintageMA
VintageMA's Avatar
06.28.2008, 11:23 PM
I've got 2 MMM's running on 6S, each using esc bec, both working for over 3 hours each.
“Everyone has a right to be stupid; some people just abuse the privilege.”
