E-sav
05.23.2008, 01:50 PM
Pipeous, does that 2400mah pack get warm? I ask as because it is meant to be a receiver pack only, the discharge rate isn't exactly great. 12 amps would make me think twice about running it in my MLST.
pipeous
5th Scale Guy
pipeous's Avatar
05.26.2008, 07:22 PM
the 2400 mah works good in the 18B/R/T... the 1800 is a better choice for the mlst. I didn't find any problem with the low c rating for the 18B because it weighs nothing.
even on road you get dirt in the spur. I have an 18R as well
jnev
jnev's Avatar
05.23.2008, 09:56 PM
After looking closer at the specs of the 2400 pack, I started thinking that it may not be enough to power the mini. So I decided to go with the Hyperion 1800 pack. It should give me plenty of run time and power hopefully.
Thanks for all the help guys!
skellyo
skellyo's Avatar
05.23.2008, 10:50 PM
The Hyperion pack should work great. I use the Flightpower 1800mAh version in my outrunner powered crawler.
Mozzy
Mozzy's Avatar
05.27.2008, 09:34 AM
Well, so far so good.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
