05.23.2008, 12:27 PM
Artur, I'm sure you've seen that the major issue so far is a failure of the BEC IC in some ESCs. There was apparently a bad batch of components to blame. Then, the fans don't seem to be lasting long.
The MMM is already a 200A controller. The only thing that would make this great would be higher voltage, but that wouldn't be near cost-effective since it seems like a mojor replacement of components would be needed.
Aside from the switching BEC unit and lack of USB port on the MMM, what would be the advantage of switching brains boards from the two ESCs?
