Go Back   RC-Monster Forums > RC-Monster Area > Customer Testimonials and Feedback
azjc
05.25.2008, 05:56 PM
Originally Posted by DRIFT_BUGGY View Post
The MMM comes with 6.5mm bullets and if you got the 1st batch that didn't, call cc and they will send them out to you. Apart from CC only other place I have seen sell 6.5mm bullets in Tower
and the ones Tower sells are CCs
pb4ugo
05.25.2008, 06:15 PM
...and the 10 ga wire I'd have to order from Offshore electrics. That's three different places (assuming I'm ordering from RC-M already). So Mike, please carry them!
azjc
05.25.2008, 06:19 PM
the ESC will come with the wire and the connectors, and I feel that 10awg wire is overkill anyways, the biggest leads coming off of lipo packs are 12awg anyways
pb4ugo
05.25.2008, 07:12 PM
Not true. I have packs with 10awg.
While 10 may in fact be overkill, the cost difference is negligible. For continuity I want 10awg.
How many motors do you have? I have many I'd like to run off my MMM, hence the need for more 6.5 bullets. Not to mention my packs, chargers, etc.
azjc
05.25.2008, 07:33 PM
I was going on what I have seen, I have never seen packs with wire that large.....I did use the 6.5s that came with my MMM but I really dont think I will come close to needing...I wont be pulling close to 200 amps
Sammus
Sammus's Avatar
05.25.2008, 09:24 PM
Should take a look at the newwer 30C (XQ?) Polyquest packs :)
Link
pb4ugo
05.25.2008, 10:12 PM
Tanic even has the option for 8awg wire!
azjc
05.26.2008, 12:45 AM
35c packs...I wonder how accurate those ratings are? so instead of a deans ultra plug they use bullet plugs, I wonder how much of a PITA is that to slide on and off?
pb4ugo
05.26.2008, 11:44 AM
Tanic is known for quality cells and accurate ratings.
Deans can't keep up with today's amp draws. They're good to 75amps. That's why I'm changing over to 6.5 bullets, like all the offshore electric guys are using larger bullets. It will be the standard in my house.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.26.2008, 12:56 AM
Yes but don't know of anyone else that cells CC 6.5mm bullets, would of thought alot more stores would of carried them when the MMM came out
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
Electric Eel
05.26.2008, 09:16 AM
All of Neu's higher amp batteries come with 10 gauge. Get used to it, 10 gauge will replace 12 gauge, just like Dean's plugs replaced Tamiya plugs. 5 years from now 4 gauge will be standard.
JOEX
05.26.2008, 10:46 AM
My LHS does!
http://www.coyotehobby.com/
pb4ugo
05.26.2008, 11:45 AM
Originally Posted by JOEX View Post
Maybe I should move to Oregon!
