rootar
rootar's Avatar
05.27.2008, 12:02 AM
ok, its actaully about the same (maybe hair slower) with the 13t and 5 inch tall badlands, they weigh the same as the 4.5 inch stock tires which i use a 15t pinion on both are in the high 30s for speed. there is ZERO binding in the drivetrain, would having the punch control set on 70% instead of my usual 30% that is really the only thing i have not ran before, also the first time i ran the badlands i used both the 15 and the 13 pinion and didnt have heat problems with either?????? it was simply to fast for the track with the 15. another note is i always run a 9.2 volt cutoff just cause ive read you never can trust these maxamps cells. i will try putting it back at 30% punch and bash it tomorrow (this is a setup i have ran before with no problems) if the temps remain ill pull the 9l apart, i guess i could have a seized bearing maybe or sumthin ........
