feigao 6xl or 3s of 8xl on 4s
drkdgglr
feigao 6xl or 3s of 8xl on 4s - 05.30.2008, 02:53 PM
What would be the better option in an e-revo (gorillamaxx conversion):
feigao 6xl with 3s lipo (aprrox. 30.000rpm)?
or feigao 8xl with 4 s lipo (approx. 30.000rpm)?
Both configurations will reach approx. 30.000rpm, so in theory they would be able to reach the same speed.
A 3s lipo configuration would be slightly cheaper and lighter, but on the other hand the 6xl will draw more amps, right?
Can anyone tell me what de advantages/disadvantages are of both configurations?
05.30.2008, 03:00 PM
Look at it this way, if you need, say 1000w to get the performance you want, the 3s/6xl setup will have to pull more current to get this than the 4s/8xl setup. So, I would go for the 4s setup - the weight gain from 3s to 4s is all but negligible.
Also, with higher current, the loaded kv is lower, so your actual loaded motor speed will be less, and might not get exactly the same top speed. Not to mention the inefficiencies dealing with high currents.
05.30.2008, 03:09 PM
5S and 9xl would be even better...
drkdgglr
05.30.2008, 03:12 PM
thanks for your reply. makes sense (though I don't know what loaded kv is...)
but what if I have more than enough current avaliable, lets say 150amps constant and 230 amps burst. With 11.1V I would have > 1500w available and 2300w availabale in bursts...???
would the points you mentioned still matter?
05.30.2008, 03:34 PM
Power = I x I * R
More current more loss i.e more heat in ESC and Motor... You don't want to be pulling 150amps constant even if your batteries are rated for it. You'd drain a pack in a couple of mins.
Feigao's are not that effecient relative to to Medusa and Neu... Heat and RPMs equal burnt windings and cracked rotors...
05.30.2008, 05:03 PM
What battery are you going to use to provide those specs? Plus, what esc are you going to use? Not many setups are going to work well on 3s in a heavy vehicle. 4s is the min, and 5s is much better.
05.30.2008, 05:05 PM
My guess is that they are looking to use a 30C 5000 or 25c 6000
05.30.2008, 05:25 PM
A 6xl on those batteries will tax them hard, unless it is geared for 30mph.
drkdgglr
05.31.2008, 03:47 AM
The type of battteries I am looking at right now are 2 4s1p 4250mah packs rated at 18-27c (hyperion lcx). If I connect them in parallel I get 4s2p, 8500mah, 153 to 230 amps?
Please correct me if I'm wrong. But that shouldn't that be sufficient?
I'm going to use a MMM. And with a 8xl looking for 40mph.
azjc
05.31.2008, 01:15 PM
I would go either 5s w/9xL or 6s w/10xL...my preference would be the 6s marriage will be the most effiecent and coolest running
tc3_racer_001
tc3_racer_001's Avatar
05.31.2008, 05:31 PM
just get 2 of those 11.1v packs and put them in series, mamba monster/125b and your set!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
05.31.2008, 05:39 PM
A pair of mid-range 3s lipos and the cooler running 10xl would be much better than any 3s 6XL setup- you would have alot more run time too.
05.31.2008, 06:32 PM
Yep, what neil said is correct.
drkdgglr
06.01.2008, 04:06 AM
thanks guys.
so looking at 6s lipo with a 10xl now. how much runtime will i get out of a 5000mah 30-60c pack?
06.01.2008, 10:21 AM
thanks guys.
Alot! That is a big battery, if you gear for 40mph, you should easily get 30mins, maybe more.
