richpadg
richpadg's Avatar
09.25.2005, 10:26 PM
Originally posted by squeeforever
then i would go with a smaller clutch bell.... with a 14 tooth clutch bell and a 40 tooth spur you can get 20.33 to 1 gear ratio in second gear.... look at your manuel that came with your revo; on page 45 there is a chart with all the gear ratios with 14,15,16 tooth clutchbells; 36,38,40 tooths spurs; and standard, close, and wide ratio gears...
I don't really understand what those numbers mean. Can you explain? The lower the number the better?
Richard C Padgett
  Send a message via Yahoo to richpadg Send a message via AIM to richpadg
