Originally Posted by Arct1k
Not really possible without a heatpump - Only suggestion is motor had cooled down and residual heat was in heatsink... This is difficult to imagine as the heatsink should be radiating more that the motor.
Only one final thought is that the heatsink was "radiating" more than the motor and fooling your temp gauage.
Or it could be the color and/or composition of the heatsink has a different emissivity rating than the motor. IR thermal probes are somewhat sensitive to that setting, which is why you are supposed to set the emissivity to whatever material/color you plan to use the most.
