Shark413
Shark413's Avatar
05.22.2008, 01:57 AM
Well no more machining for a while, my bad machining skills blew the gear box in my mini mill. But I was able to finish the spacers the old fashion way, saw, dremel and files.
Broken gear - Mini Mill
Carbon Fiber spacer for front diff support
Aluminum spacer for diff/motor mount.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
cen
cornolio
cornolio's Avatar
cen - 05.23.2008, 04:02 AM
hi shark413,im the guy who got your old cen conversion.im having so much fun with it with the MMM.only problem is i keep stripping spur gears.i stripped 3 already and and im not even doing any jumping.i got a steel spur gear but im reluctant to try it coz i might melt my pinions or something else.can u give any advice?id appreciate it.thanks
  Send a message via Yahoo to cornolio
Shark413
Shark413's Avatar
05.23.2008, 01:09 PM
cornolio, glad to hear from you. I also had issues with stripping the plastic Kyosho spur gears, so I swithced to steel spur and a hardened pinion. I have been running these on all my brushless conversions with no problems. The important thing is you must use a Mod 1 hardened pinion, which RC-Monster, Impaktrc, MegaUSA all sell. I am also using a wide Robinson Racing Losi spur gear that is wider than normal and spreads the contact area out more, which improves wear on the spur and pinion as well.
http://www.amainhobbies.com/product_...ducts_id/12711
Spur comes in 47, 48 and 49T.
cornolio
cornolio's Avatar
05.23.2008, 01:48 PM
thanks shark.sorry for hijacking your thread
Shark413
Shark413's Avatar
05.23.2008, 04:20 PM
cornolio, no problem. Just to clarify, if you switch to a steel spur the hardened pinion is a must. The wide Robinson Racing steel spur is optional and a nice to have but not a requirement.
Shark413
Shark413's Avatar
05.23.2008, 07:06 PM
Ok, got the mud guards and installed them.
Shark413
Shark413's Avatar
05.24.2008, 12:03 AM
Updated photo.
cornolio
cornolio's Avatar
05.25.2008, 12:16 PM
another question.what oil weight do you use for your center diff?thanks
Shark413
Shark413's Avatar
05.26.2008, 11:43 PM
cornolio, I am currently running what Kyosho recommends, 7000 wt in the center diff, 5000 in front and 2000 in the rear. I find these are good starting points for my set-up.
Shark413
Shark413's Avatar
06.03.2008, 02:49 AM
Ok, I finally was able to get (bribe) my nephews to come out to the track and shoot some video of my brushless ST-RR in action. Still need to fine tune the shocks and brakes.
http://www.youtube.com/watch?v=GC9rYX8hLPk
Updated with a better quality video
Steve Krug
Steve Krug's Avatar
06.03.2008, 10:54 PM
Is your MM fan powered from the receiver then I assume?
Watched the vid, good driving and even better truck :)
Were you having problems with the electronic brakes then so you switched to mechanical?
Shark413
Shark413's Avatar
06.03.2008, 11:06 PM
Steve, thanks for the kind words. I am a better wrench than a driver. The fan runs off of the rx. Regarding the brakes, I just feel more comfortable with the mechanical brakes, you can adjust brake bias, there is less wear and tear on the gears/motor/esc. When you use motor brake only you bascially lock the spur gear, but the diff will then decide how much brake to give to the front/rear depending on traction. Too iffy for me. Don't get me wrong, motor brakes work fine, it makes the buggy lighter and there are less things that can go wrong.
cadima
06.04.2008, 12:29 AM
shark, nice job on the conversion.....lot of work. FYI....running the neu with the wires oriented on the low side will eventually result in pierced heat shrink on the wires where they smack the chassis and can short through the chassis intermittently.......
Shark413
Shark413's Avatar
06.04.2008, 01:51 AM
cadima, thanks for the heads up, I'll keep an eye on the wires rubbing on the chassis. I was kind of worried about the wires where they exit the motor can, do they rub agains't the can and short out? I was thinking of putting a dab of silicone sealer around the holes to both seal the can and prevent the wires from rubbing.
Shark413
Shark413's Avatar
06.04.2008, 04:02 AM
Here is part 2 of the video.
http://www.youtube.com/watch?v=QnwpWq7kynA
