>or i will reduce the runtime, raise the current and temperature
This is exactly what will happen when you increase voltage without changing gearing. So yes, if you increase voltage and you don't want to go faster and want to benefit from lower currents you have to change gearing. Why do want to go down on current? Do you have heat issues with your ESC, motor, battery?
