blueb8llz
06.12.2008, 03:47 AM
was the lvc set the same with 2,3, and 4s? because if you have the lvc set real low...like say 3 volts per cell, then you ll notice a decrease in performance before the lvc hits.
speed demon
06.12.2008, 08:11 AM
The 2S was set for 3v per cell the 3S and 4S were set for 3.1v per cell.
lutach
lutach's Avatar
06.12.2008, 09:59 AM
Were you using the same gearing on 4S or 5S that you have with 3S? If so you, everytime you go up in cell count you will only be drawing more AMPs. Try a smaller pinion or a bigger spur and gear it for the same speed as you were getting from 3S. My 1521/1Y on 10S lipo with the same gearing I use with 6S will draw a lot of AMPs.
speed demon
06.12.2008, 10:08 AM
I am just trying to find out if the loss in power before the pack reachs 3v per cell is normal the higher you go. I ordered a 5S but when my money order got there they were out of stock so he is sending me a 6S for the same price. I'm worried because my MM won't have low voltage cutoff but if this trend I see keeps going I won't have to worry about it. Really don't want to push the MM that far but want more speed and I'm going to wait before I get an MMM.
