Originally Posted by TexasSP
The shutdown is the thermal shutdown in the control and means it is over heating. The other part could be part of that or something else.
As far as your English, it is much better than many Americans I know so don't worry.
hi texasSP, you mean that the esc is over heating? cause i touch it and it is a little warm, but the motor burns as hell. The problem is more usually when i run the esc on the truggy, it is a x1crt with a feigao 9l and 4s 5000mah lipo. Maybe the motor over heats cause the stock spur gear is 62 i think, but i changed it to a 46 one from kyosho, cause i have read that plastic spurgears are better for brushless conversions, the pinion is the smallest that i can found on rcmonster store, a 12 teeth mod1 if im not wrong. I know is a brutal jump between 62 and 46 spur gear, but with the 62 steel spur gear the car was very noisy and i was worried about breake the spur.
Here you are a vid of my truggy with 9l feigao, 4s lipo and a mamba max that i decided to change it cause it over heat a lot
http://www.youtube.com/watch?v=mDST5720QBo
So just one question; it is probably that the esc make this strange cause the motor over heat? or the esc cant know that the motor is over heating??
maybe is a stupid question but i dont know anything about electric cars, i just know they are really funny.
Thanx for the support again guys
