JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
06.16.2008, 09:10 AM
Originally Posted by asheck View Post
Are you saying thats on a 4.5 motor?Because I don't think it would do it.
Yep, Novak 4.5HV with 2 3s Maxamps 5000mah run in parallel. Why don't you think it would do it? Your truck does it and they are roughly the same weight but I'm geared taller.I know Maxamps aren't the best batteries but running them in parallel helps them hold their voltage under load, so I might actually be running the same voltage as you under wot. I'm not sure of the exact batteries you are using so I can't say for sure.
