06.17.2008, 12:43 AM
Originally Posted by DwightSchrute View Post
this might sound silly, but will doing a standing burnout hurt my brushless motor?
as in spinning the tires till they get hot with the rusty facing a curb?
the reason i ask is i'm trying to find a good way to heat up my tires for a little better traction on the street.
I used to just hold the vehicle off the ground a bit and give it some gas to warm the tires up. I figured as long as you are not going full throttle you will be fine. You may overrev the motor or throw a tire if you do it full tilt.
