Linc you could just drive to the southshore...nah I'll keep them.
What do you mean by putting out? Since it is between the batts and the esc probably not??
My batteries at full charge are 16.5 volts?
Just re-read your inital post. You had the truck off the ground when you tested it. Sounds about right for a no load pull. The tires and diffs take some power to turn, that is for sure.
