aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.28.2005, 09:19 AM
I know how you an run 18 cells on the EVX.. I've done it...
those two connectors for the batteries.. one of them is connected to the BEC, and the other is not...
use a regular 7.2Volt, and test it on either one of the battery connecter.. if it lights up, then this is the one where you want to use 6 cells....
Let me try sticking 2 3s lipo packs on it.. I have an evx on my 4x4 Rusty.. if I fry it.. I don't care... it's in the name of RC.. if it works.. I'll take a pic I'll be back in a couple of minutes... I don't want to give you advice that'll blow up ur ESC.. so I'll take a risc of blowin' up mine..
or
this way, you'll have no reverse...
Stick the regular 2 packs of 6 cells on the ESC.. and where the esc connects to the motor... stick another 6 cell pack directly to the motor... black wire on negative. red wire on positive.. this will work too.. but you're titan will probably fry.. :)
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
