Originally Posted by abiye
if you lower the frame rate setting to 5.5ms you'll notice the speed difference... you need to have digital servos howerver... i'm running ace 1015 servos in my losi 8's... also i'm using lipo rx pack without a regulator... at 6v they're rated at .10, at 8.4, silly fast... with the 5.5ms setting you can't even see the wheel... lol
I am running digital servos and the 5.5 frame rate... Still cant tell a difference. The faster frame rate doesn't make the servos move faster, it just reduces the latency from when you turn the wheel to when the servo starts to move. When these things start getting measured in mili-seconds its beyond my mortal abilities to tell the difference. I'm sure there is probably sombody who can...but not me.
