Edumakated
06.18.2008, 04:30 PM
I used 25mm novak fans. They plug into the receiver. If you are running the 1.5d, you will want to run two fans. One on the heat sink and then cut a hole in the case and run one blowing directly onto the esc board. The 1.5d is a very powerful motor and pulls a lot of amps, so you want as much cooling as possible on the ESC.
