Originally Posted by redshift
I left a few things out of my first post.
I am running a 9XL with an RCM pinion, setscrew out. To get full mesh the setscrew is out as far as I can go. In other words I can't grind it, the setscrew will be on the edge of forcing the pinion off, so in my case I'm hoping there is enough bite without grinding it, only using Loctite....
My S600 motors on my Emaxx are in same situation, caused by motor shaft being shorter than the Titans they are replacing. I was concerned like you that pinion would come off after running a while. I am barely on the edge of the shaft and use a flat spot and blue loctite. About 2 dozen runs later, nothing has come off and I've stopped worrying about it.
I use motor spray to clean both set screw and the set screw hole before applying blue loctite. Any trace of oil on either - loctite will either not set at all or only develop part of its full strength. Also have to give it some time to set.
