I like this bearing idea alot. I might try messing with this a bit. I'm thinking a 5x10x4mm flanged bearing would work perfectly if the back side of the motor front plate were milled out to accept the flange, the bearing couldnt fall out without taking the plate off, yet still very easy to remove for maintenece.
to make it...
or break it...
