Pdelcast
Pdelcast's Avatar
06.23.2008, 03:54 PM
Yea. But with 5s support. The current MM is a bit hit or miss on running 5s with a fully charged pack. Some will start and work perfectly, others will not, and yet others will work on 5s if you turn them off and on enough times to just get the peak off of the pack and then they work perfectly on 5s. Just want to see it work on 5s properly all the time.
The MM isn't made to handle 5S - -the back-EMF resistors and sense resistors are wrong, plus the linears are overloaded at 5S...
I'll look into making a 5s capable control board for the MM -- if you think that will be sufficient.
Thanx!
Patrick del Castillo
President, Principle Engineer
