06.23.2008, 09:05 PM
First of all, what are you using to read those temps? IR sensors can be sensitive to the emissivity setting, and since black radiates heat better, it could be tricking the sensor into thinking it's hotter than it is. Does the motor actually feel that hot?
Second, you mentioned changing the CD oil. Was there a change in temps before and after the change? I set my Hyper8 (1512/2d on 4s) with 50k diff oil and temps are great.
VintageMA
VintageMA's Avatar
06.23.2008, 09:28 PM
Brian - using a Flahpoint set to 77E. Hard to tell how accurate it is, but yes the motor is definitely to hot to touch for more than a brief moment.
MMM is hard to measure through the plastic, but it was registering in the low 100s. Battery was coming in at ~120-125*.
I don't think there has really been a temp change before and after the diff oil change.
Only real difference I can tell is the MMM - my motors seem to be hotter than on the MM with very similar setups. I ran a teckno 1515/2.5d through this exact same setup geared at 14/46 with 6S and it was getting up to 150+ as well.
“Everyone has a right to be stupid; some people just abuse the privilege.”
