If the value "10" on the motor timming case is the value giving in degree, i find it little high for a "d" motor. Try to put it at 0, or if you have the option "automatic timming" as on the MGM controller, put it on automatic.
Thanks, ill give that a try, the 10 is what the ESC was set to and it said normal so I just left it at that
