cant get mod1 mm to go
rootar
rootar's Avatar
cant get mod1 mm to go - 06.26.2008, 08:35 PM
got the Mod1 MM from artur yesterady and i finished the install today, at first i couldnt get it to arm or setup on 5s, turned out it was my radio, switched to a new AM 2ch i had laying around and then i got it to take the setup you do with your radio, when its just sitting there i have two red leds lit, give it gas brighter led just blinks, give it brake opposite led blinks bright????? is this the over votlage? i set the cutoff to none and i have it all hooked up correctly because 3s works perfectly fine. ?????????????????????somone help me out
