sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
06.27.2008, 08:35 PM
Originally Posted by Dadx2mj View Post
Wow what a negative attitude. The tiny amount of current the fan draws is not effecting my run time at all. Even if it did with summer coming on it would be well worth the piece of mind it gives me knowing the ESC is staying as cool as it can.
Negative? How is pointing out pointless mods negative? What you did offers ZERO benefit, and actually creates a performance hit.
I wouldn't even consider a fan unless my ESC ran 180, I had tried everything to lower it and had no success. I run in Houston (yeah, where the real summer is) and I've not had ANY heat problems EVER running 2S. Putting a fan on a mamba 2S system is just laughable.
I guess if it makes you happy, go for it.
Jeremy1976
06.27.2008, 09:03 PM
Well I had to put a fan on mine. I ended up buying another brand new one and swapped them out and put the deans connectors on just to see if that may have been a issue. Same thing, up around 200 degrees within minutes with all my settings as low as they go. I put the novak fan on and temps were around 130-140. Ambient temps here were 72 degrees when running. I am running a Tekno Neu, 2s 8k lipos, (4s), 22/58 gearing, CC BEC.
azjc
06.28.2008, 03:17 AM
its only 72 degs....when I wake up @ 0700 its pushing 90 degs here....:-0
Dadx2mj
Dadx2mj's Avatar
06.28.2008, 11:39 AM
Believe what you want I am a firm believer in cooler electronics work better for longer. You thinking the tiny little fan is going to hurt performance is what is laughable.
Blindman Racing
Powered by Mamba 5700
Wakesurfer
06.28.2008, 12:07 PM
Hasn't been to bad here yet this year, but 100dF with 99.9% humidity is not unusal for a St.Louis summer. I probably wouldn't need a pair of fans for a 1/10 2wd ST, but a 3905 Maxx on 4S puts a little more heat in the ESC.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.28.2008, 06:20 PM
Anyone know what the CFM is on the standard MMM fan?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
phatmonk
RC carbon junkie
phatmonk's Avatar
06.28.2008, 10:26 PM
I found a 5v 30x30mm magnetic levitation fan that I have on my MM running 4s with a Neu 1515/1.5d.This fan puts out 4.9 cfm compared to a novak at 2.5cfm.
TruckBasher
TruckBasher's Avatar
07.01.2008, 09:03 PM
Where did you buy this fan? pics?
Also a question, I just manage to ARM my MM with 16.5V (5S a123) even with a custom Voltage cutoff :) anyway, do you think I can use the red wire from MM to power the fan (only) and still run 5S A123?
E-Slayer direct drive to diff
phatmonk
RC carbon junkie
phatmonk's Avatar
07.01.2008, 09:22 PM
This Sunon fan actually use magnetic levitation to "float" the spinning fan blade in a magnetic field to dramatically reduce friction, wear, and heat; making these fans run cooler, quieter and last longer than conventional fans. Ideal for use in any mission critical application, in applications where minimal fan noise is desired.This is a direct description from the Buyextras.com.This fan puts out double CFM then the Novak 2.5cfm 4.9 cfm compared to the Novak.I run my fan off the receiver and run 4s 14.8 and a CC BEC.I run a neu 15151.5d/f.I run my Brushless 8T in 80 degrees outside temp for 30 minutes and no thermal issues.
TruckBasher
07.01.2008, 09:29 PM
Thanks for the Fan info. For the Fan power source I also use the Rx but I was hoping to use the BEC of the ESC since its just a small fan but I guess it will be safer to jsut use the RX to power the fan
phatmonk
RC carbon junkie
phatmonk's Avatar
07.14.2008, 09:23 PM
Heres a photo of my 30mm Magnetic Levitation fan on my MM.This little baby puts out 4.9cfm.
tc3_racer_001
tc3_racer_001's Avatar
07.15.2008, 03:54 AM
where can i get one of these???
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
DRIFT_BUGGY
07.15.2008, 08:05 AM
How much does that cost and where did you get it from?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
07.15.2008, 05:22 PM
$15-$20 posted i would get one... and hope it wouldnt break. anything more and i probably wouldnt bother seeing as i can get 5 and 12v fans for $7, sometimes with a cheapo heatsink!
are these available worldwide as ive never seen or heard of them before
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
phatmonk
RC carbon junkie
phatmonk's Avatar
07.15.2008, 07:19 PM
This is the page address its from buyextra.com
http://www.buyextras.com/su30dc5vmale.html
