Duster_360
06.28.2008, 05:11 PM
That's the easiest - just wire them so you have a plug that'll plugin the batt slot in the rx. This drains a little away from the servos, but unless you get a power draining fan, it shouldn't be noticeable.
If you're runnning nitro, its for a batt. If you have a 3rd channels in the rx you could you use that if you were running nitro - all the slots have power.
BoilermakerU
06.29.2008, 03:54 PM
Originally Posted by Duster_360 View Post
...just wire them so you have a plug that'll plugin the batt slot in the rx. This drains a little away from the servos, but unless you get a power draining fan, it shouldn't be noticeable...
Thanks, that helps. I'm getting the Novak fans mentioned, so according to tc3 racer, a piece of bark draws more current!
I'll just wire them all into one plug ans plug it into the reciever. Here's hoping for cooler runs!
