83gt
06.29.2008, 12:23 PM
Handles great, although I need a stronger servo, or at the least a metal servo horn. The 9xl is pushing it around at good speeds. I need to get some proper wheels, as the ones I have I had been using on e-savage to widen the track. They are offset all the way out. It makes the hellfire look a bit goofy being so wide. I'm thinking on just getting the stock black dish rims and switching the tires over.
All in all, I really like it quite a lot. I have thought of a flat piece of aluminum cut on an angle to go from the rear shock tower to the chassis. Then I could use a delrin block bolted to the bottom and rear, using that to bolt to the chassis and shock tower. It's fairly firm as it is, but additional chassis bracing seems needed.
I'll definitely be looking into a MMM and Neu combo as soon as I can afford the shopping...
J.
