Originally Posted by david lamontagn
I think that with my 1515 2.5d and 6s, i'll be not to bad with 22/68, but i've RRP MOD .8 pinion 20T and 21T on the way
David - you and I are running the exact same setup with the badlands - and running last weekend on 18/62 (equiv to 20/68) I can see 20/62 (24/68) being a good setup - but the badlands really don't balloon too bad.
You had recommended the badlands setup to me in a pm and I got the tires with the maximizer bead locks and they are a perfect bashing combo.
With the regular stock Talons you might as well take the diameter of 5.9" and add an additional 2" to the diameter if you gear for 35 or more.
SJCRSS - if you have the options of getting a few pinions I would go low and then work your way up, but either way you will love this truck - I've been having a blast with it so far.
