DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.29.2008, 09:58 PM
Well just got back from the track. With it a 3 degree the motor still got up to 170F and the ESC up to 128F, battery 95F - 110F. Im now going to set the timing to 0 and put the larger 15T pinion in instead of the 14T which will raise the top speed to 47mph. My local track is fairly large. I have some thicker centre diff fluid (10000, standard in roller 8ight is 5000) coming to. If that doesn't change the temp I might look at putting a fan behind the rc box which will flow air straight onto the motor and try to work out how to go more air flow to the motor. This is a great buggy to drive and once I work out how to get the motor to stay cool, im laughing
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
